random J2
random J2
I've got a machine that is acting funny. It will run for like 7 or more frames then will randomly give a J2 error code. I've made adjustments to it and the problem still happens. The pinion gear on the 7-pin side was replaced a month ago but this problem just started a week ago. Table is leavel back to front and side to side. Any answers?Tags: None
If it is happening that often, i'd sit on the machine and run it in diagnostics to watch for binding, slippage or any other odd looking actions as the table goes through its motions.
Maybe some of the wiring got pinched while doing maintenance in the area there and so vibrations; movements are causing intermittent issues.
