Not Setting Pin 9
  • Not Setting Pin 9
    Hey guys... me again... im havein a problem with my lane 9.. it wont set pin 9. i've changed the pin cup, switch the IO boards for a working one, changed the Loom that goes from the table to the consolidated box, looked for broken wires and checked the table height and none of these have sorted or moved or done anything to this.
    Any ideas??
    Does it drop in to pin holder and pin grippers remain open or do the pin grippers remain close and not open to release pin from pin station? The first is the CPU is not getting info from switch, the other is a power or solenoid problem. The other thing is the grippers could open but not cause pin to release, usually an adjustment will correct this.
    Here's a couple of things to check for if all else checks good. Check for a pin pushed out of the connector where the main cable connects to the table harness, and check for a pushed back pin or broken wire in the connector where the main cable connects to the side of the consolidated box. Also there could be a pinched/broken wire that is hard to find unless you ohm the wire out. Ohm out to the table plug to confirm table harness is good, then ohm from table plug to consolidated box to confirm the main cable didn't get damaged while installing.
      thanks mate i will have a look but i cant check the Ohm coz i dont have a multi meter when my company was brought out the old company took almost everythin so im still tryin to regain all my tools lol
      Help-broken Part
      Greeting all.
      Thanks for looking.
      Bolton454
      Pin Damage
      Making TDM's adjustable.
      Gold Crown Masking Unit
