Not Setting #5 pin
  • Not Setting #5 pin
    I have a lane not setting 5 pin intermitently. Changed holder. The grippers are not opening to hit release button. Acting like it is "detecting" a pin in holder. Check lower and upper harnesses is what I am going to do when league is finished. Any thoughts are welcome.
    Times like this just toss a spare table cable by the walkway from nex gen to table as a temporary fix and wire it in properly when the league is done.
    Help-broken Part
    Greeting all.
    Thanks for looking.
    Bolton454
    Pin Damage
    Making TDM's adjustable.
    1:1 shaft wear
