moving deck cam lever removal
  • moving deck cam lever removal
    what is the best passion to remove this part would it be 270?
    Yes 270 setting new pins. Remove the deck cable then good to go.
      thank you
        Yes 270. I have dissembled two machines and put them back together, make sure you wear gloves and use an old rag.
        Help-broken Part
        Greeting all.
        Thanks for looking.
        Bolton454
        Pin Damage
        Making TDM's adjustable.
        1:1 shaft wear
