Rectifier swap?
  • Rectifier swap?
    My machines currently have the original selenium rectifier usa built. I'm wanting to know if the new flat-pack type rectifier is just able to be swapped over 20200310_191309.jpg
    Yes, just follow the wiring diagram.
      May want to look at this post:
      Preventative Maintenance - Brunswick Selenium Rectifier "A's"
      Help-broken Part
      Greeting all.
      Thanks for looking.
      Bolton454
      Pin Damage
      Making TDM's adjustable.
      1:1 shaft wear
