Mini-pinsetter
  • Mini-pinsetter
    I have some updates on my mini-pinsetter I've posted about here before. Enjoy: https://www.youtube.com/watch?v=Ac1rugg5Fuw&t=53s
    What kind of pinsetter is that? It’s interesting
    The older the part, the STRONGER it is.
      It's my own design. It is patented. It runs half size bowling pins through it but could easily be scaled up to full size or duckpins if desired.
        Impressive engineering there
          Thanks. Appreciate it.
            Very cool! Thanks for sharing!
            Help-broken Part
            Greeting all.
            Thanks for looking.
            Bolton454
            Pin Damage
            Making TDM's adjustable.
            1:1 shaft wear
