Short Version: Can I use a BT M4 to trigger my A2s using the TDM removal process?
So I have read the post about how to remove the TDM from a machine using existing Triggering. I am trying to figure out If I can use my BT-M4 to do the cycling or not. The wires that go to the TDM have a constant read of 24vdc, Which is odd to me given the 26-28vac machine use, but I figure the TDM uses the points differently since #16 runs through the power input and 18 hits the transistor and relay. All my BT paperwork doesn't offer a theory of operation, nor do the TDMs, Which I guess is understandable, except mapping a TDM and its machine wiring just seems like a big loop. We burn through about 6 TDMs a month and I replace blown caps and resistors as I can. But when I have to purchase new ones it gets rather expensive.
