Looking for electrical box info
  • Looking for electrical box info
    I have older A's that were converted. The wiring appears to be original on most machines. I have 2 right now that refuse to power up (we can run them manually triggering the relay). I am wondering if there is a source for new or rebuilt boxes. I can probably rebuild them myself, but that's a lot of time that I need to be using elsewhere.
    As for the ones that don't run. My mechanic replaced all the microswitches, relay and transformer. The mechanic switches both test good. We installed new scoring, about 10 days later this happened. It will not run even with the scoring unhooked.
    Thanks
    There's a helpful troubleshooting guide by Roscoe in the tech reference sub forum that may help you.
    https://www.bowltech.com/forum/pinse...ough#post18311
      Have you checked the fusestat?
        Thanks for the replies. We got 7 running, by swapping the screw in fuse with lane 8. Why that worked, I have no idea.. we took that out an checked it half a dozen times then it just decides to work. 3 is still down, we wired it according to the diagrams and its a no go. So, now my mechanic is wiring it back to match the other lanes and see if it will run.
