CLUTCH RESET LEVER
  • CLUTCH RESET LEVER
    does anyone know the part numbers to the roller and pin that goes to the double armed reset lever?
    I can only find the part number for the single arm
    Go to the link below. Page 44 shows the lever and all the related parts for it.
    https://brunswickbowling.com/uploads...ts_Catalog.pdf
      Don't believe the lever has been available for some time. If the hole elongate in the arm, you can drill out and put a small oilite bearing in there.
      Bearing 11-433000-000 Pin 12-100318-002
        Here is the info from the catalogue.
        ALL Files Scanned with MALWAREBYTES PREMIUM Version 4.4.5.130
          If your reset lever looks like this and it's older, it's a Quality Bowl and needs a bolt instead of a pin. Looks like Kegel is selling them now.
            My bad .... thinking of wrong part.? 29 instead of 22. Got tricked when you mentioned double armed as mine were all double armed "Clutch Levers".
              If your reset lever looks like this the X pin is 10-229 007-000, 2 rollers are 12-100 030-007, bearing is 11-481 028-000. This is from page 29 of the paper parts catalog.
                those are the ones i have.. i really dont like the nut and bolt system... im using part #12-100030-2 for the roller and 12-100166-19 for the pin...
