Am I missing something?
Removing hook selector with detector on machine
It seems to me that all that is needed is to knock the roll pin out of the flag selector and remove it from the shaft and to knock the roll pin out of the strike cam follower. It would seem that this would allow the shaft to be moved toward the 10 pins side and the hook selector is free.
Am I missing something?If you think my girlfriend can fight, you should see her box!Tags: None
Members
- May 1999
- 1176
- Brunswick JB and A2, AMF
- Sync, Vector Plus
- Kegel Lane Walker / Kusto
- Brunswick Prolane
- 1973
That was ridiculously easy. I don't agree with pushing the shaft toward the 7 side. Much simpler to push it toward the 10 side.If you think my girlfriend can fight, you should see her box!
- 1 like
Member
- Mar 2004
- 3228
- Brunswick A & A2
- Qubica, accu score, compu
- Authority 22, Phoenix, ce
- Timber, Synthetic
- 1985
Rather more work to replace the whole thing, isn't it?If you think my girlfriend can fight, you should see her box!
- 1 like
Member
- Mar 2004
- 3228
- Brunswick A & A2
- Timber, Synthetic
- 1985
Originally posted by Jack_Sparrow View PostRather more work to replace the whole thing, isn't it?
Personally, I would spend the extra 10 minutes and remove half a dozen pins and a few bolts and replace the entire detector.
Gives me the chance to clean where I can't normally reach and install a shiny new refurbished unit.
Member
- Aug 2003
- 2686
- 82/70, 82/90XL, A2(27:1),
- AccuScore Plus
- Kegel Flex Walker
- DBA IQ/Pro Anvilane
- 1973
I've done it both ways (swap detector and pulling just the D-shaft).
If the detector was rebuilt recently and the RHS bearing just broke I preferred doing it in the machine.
The ONE caveat in removing the D-shaft in the machine is if you happen to have any brass shims on the shaft. Some detector shafts are shimmed to keep the selectors aligned with the cams. This happened to me once and I wasted almost an hour trying to get a shaft back in before I realized two shims next to the 180 stop selector had slipped just 1/8" and blocked the shaft from going back in.-- Larry
Member
- Mar 2004
- 3228
- Brunswick A & A2
- Timber, Synthetic
- 1985
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
