Which cable will replace this?
  • Which cable will replace this?
    So the cable that runs from the deck jam tube, on my model A, is all kinds of gnarled up. My question is, I believe one of the moving deck cables would work for it, but which one? The upper cable or lower? Or is it it's own cable all together? I can't find it.
    Re: Which cable will replace this?
    It is its own cable
    B Mechanic Freeway Lanes of Parma
    42 Old Otis A's, Steltronic Scoring, Kegel ION Sport
      Ok, it being it's own cable, anyone have a part number for me?
        12-100280-000
          Originally posted by the guy
          12-100280-000
          12-100280 IS UPPER CONTROL CABLE IN THE TUB
          12-2000066-2 IS UPPER CABLE
          12-200066-4 IS LOWER DECK CABLE
          MY ADVICE IS TWO REPLACE ALL THREE [ SAVES TIME LATTER ]
            Do you have the tool to replace the cable?
            12-700110
              the different cable lengths are all in the catalogue or u could measure the old one to the new one. u must have spares for each cable
                If the "old" cable is stretched, then measuring it will be a small waste of your time. Write down the measurements of each cable as it is stated in the Quality book alon with the part number, and when you order them, just hang them up in their respective area. I would recommend measuring the "NEW" cables to make sure they arte the length they are supposed to be. Because this is where you can get into trouble.
                  The only cables that can be "mixed" up are the upper deck and upper sissors.With the sissors being shorter than the deck.
                  rfm
                    There is a tool you can buy to replace the cable inside too a spring compressor it literally will pay for it self in know time I love mine but if you cant afford one use a vice...
                      Dane
                      I respectfully disagree...do NOT use a vise to remove the cable. If you do not have the proper tool...get one. Your safety is more important than the few bucks this thing costs.
                        Originally posted by Steve Stafford (JBEES)
                        Dane
                        Totally agree safty first
                          while it IS possible to dis-assemble a tube assm. w/o the tool,it is NOT possible to re-assemble it that way,and as professor Stafford stated,do not try any of this without that tool.
                          wish i had the same access to that infallible source of expertise on lane conditions that bowlers seem to have....
                            Originally posted by jmac33
                            ...it is NOT possible to re-assemble it that way...
                            Although I agree safety first and I too recommend the tool but I have to disagree with jmac33 here. I have, in my earlier years, changed many without the tool because at the time I did not have one. I used the vise with a deep socket that I notched out. But once again, I do NOT condone this method. Get the tool and be safe.
                            "Efficiency is, doing better what is already being done!"
                            Broken Things!
                            Help-broken Part
                            Greeting all.
                            Thanks for looking.
                            Bolton454
                            Pin Damage
                            Gold Crown Masking Unit
