Rake sweep problem
  • Rake sweep problem
    this weekend one of my pinsetters would sweep strangly. it would sweep normal till it got about half way back then seem to lift up way to high and even caught the pins that hung by the scissors. of couse I was gone. they said it happens at random and I can only get it to happen on first ball. and if I bowl on it, so I can't see what is happening. any Ideas?
    I reject your reality and substatute my own. (MB)
    I'd check all your cushion hardware and linkages. Then, check to make sure the shotgun is latching properly. If you can't find anything, make sure your bearing on the rake cam follower is in good shape.
      this machine has the "pit cushion cam and roller kit from pin setter parts plus
        One of the bolt that holds the cushion to the cushion mount was missing.don't know if that would cause this.
          Check the rake timing. Adj #3 page 3-8 step 5.
          jonesborobowl.com
            Make sure all your hardware is on and tight on your cushion....seems like a good place to start. Then it wouldn't hurt to go through a full rake ajustment.....Steve Stafford has a good one.
            If it is not happening all the time I wouldnt think that it is a rake cam adjustment....If it is all the time, then definatly a rake cam adjustment is probably your #1 culprit.
            Nick
              If it is intermittent, it will most likely be in the pit cushion linkage. The cam and roller kit might have a bolt that has come loose getting caught on the pit cushion itself. You could also look at the curtain hangers mounted to the pit cushion. They might be catching something...especially if they have come loose.
              If you need a copy of the rale adjustment...let me know. I can send you a copy or we can post it here for you.
                If you have the wiring bracket thats installed on the 7 side rake at the top make certain there is clearance between it and the rabbit ear bolts.
                rfm
                  Could it be that rake got hit knocking off rack cam timeing
                    hey steve I'm always wanting to learn, and would like to see this rake adjustment. post here or send it's up to you.
                    thanks for all the responces.
                      If this was the case, it would do it every time. He stated that it didn't do it every time so I stayed away from a timing issue.
                        a few months ago I had a lane doing the same thing and it was because one of the bolts that mounts the cushion to the cushion mount broke at about the middle of its length and the half with the threaded shaft and stuck out of the cushion mount and was jamming up against the support arm at 180 degrees causing the rake to raise
                        Nick
                          I know you stated it only does it in first ball..... Could it be doing it in second ball and you just dont know because there are no pins for the rake board to grab onto ? Me personally it sounds like the the cam got knocked out of adjustment or the cam follower bearing is falling off or something cause it sounds like you are describing it happening around the 2,3 - 4,5,6 when the cam is in position to be adjusted to the 5/8 height from the lane surface. Just a thought. I would deff. check crank rod, well..... I would just go through the entire series adjustment. Good luck to ya
                            Rake cam timimg may just be it. If one turns the cam too far it will go high enough and touch the pins...oh yeah,it will indeed. That's how i learned about the timing by playin' around a bit.Small movements of the cam can make it do various things in the sweep action.
                            Heck...at a center they had the rake sweep BEHIND the deck at zero due to a ball smacking the sweep at the right time!! That was fun...not.
                            This is why as of today i HATE counter ppl for letting bowlers hit the sweeps and not having guts to tell the bowler to not do that.It can be a costly item to repair when something goes very wrong.Having bowlerse come in and do stupid things for fun (like hit sweeps) gives the impression the center doesn't care so they do stupid things.
                              As stated above,
                              cant be rake cam timing if its not doing it all the time
                              Mike
                              • Titan
                                A-2 Rake problem
                                by Titan
                                I've been through all the adjustments and can get the rake to sweep properly. A day or so later, while sweeping the rake gets extremely high towers back of pin deck, misses pins...
                                01-22-2014, 07:37 AM
                              • jestertat
                                Rake raises during sweep
                                by jestertat
                                I have a rake that raises up at the back of the deck and when it comes forward, it hits the bottom of the pins that are being raised from 1st to 2nd ball. Because of it raising...
                                06-15-2010, 01:18 PM
                              • pinmechanic
                                Rake High/Cushion Low
                                by pinmechanic
                                Title pretty much sums it up. I've got a lane that the cushion sags low, and the rake is about 6 inches too high at guard. Machine has to go into 180 before the ball rolls under...
                                01-03-2010, 01:37 AM
                              • nighthawk
                                weird sweep action
                                by nighthawk
                                Replaced missing,bad sweep arm bushings and now the rake is twisted twords the 10 pin side due to a poor weld alignment from past mechanic(sweep arms are not straight and true),that...
                                06-03-2005, 11:54 PM
                              • jaysen
                                rake does not drop
                                by jaysen
                                i just finished rebuilding the pit links and triangle plates on a pair of lanes. now both rakes drop down only half way untill the pinsetter starts to cycle. im using the new...
                                12-01-2004, 09:59 PM
                              Deck Lift Gear Damaged
                              Starting Issue, Random Cycling of Pinsetter
                              Noticed that the Rake Crank Arm had a jerk/stutter on 2nd pass of 4 phase movement. Hand cranked to movement point and felt solid...
                              Streamlane Mask Halo Lights
                              Baddest Tool Chest In Town
                              Adios, motor boater!
                              Aluminum Repair and Welding
                              http://aluminumrepair.com/...
                              Hi, guys.
                              check this jam...
                              the ball stuck the table up
