Moving Deck Bind?
  • Moving Deck Bind?
    On an A-2 what would or could cause the moving deck to shift forward about a 1/2 more after the turret has dropped the pins in the chutes and the deck starts to move down to set pins causing a pin or two to get caught in the chutes causing a blackout? I've checked the cables for binding,blew out the deck with air to remove foreign objects. the deck doesn't to seem to be binding. It acts like a chute is hitting on the turret and not letting it shift all the way forward. I would appreciate some help. Thanks in advance Greg
    Possible twist in 1:1 shaft.
    Advance the GB timing until it stops. See adjustment #9 page 3-13/14 in manual.
    Put a note on the rear guard noting that timing is advanced so nobody adjusts it back.
    jonesborobowl.com
      sounds like one of two things maybe both a little check to see if your gear box is stoping on time and not stoping to soon as when it starts to cycle it will cause the deck to shift forwards a bit .the other thing would be to check the cable adjustment but that could be more of a pins falling on respot from scissors good luck
      keep it simple
        Check your deck chute and spotting finger bolts. One of them may be broken, causing the bolt to drop, which will cause the deck to bind when it shifts.
          Either your gear box is stopping slightly before 0 degrees, or you have a 1:1 with play in the moving deck scissor cam that needs to be advanced a little past 0 degrees to ensure that the deck is shift all the way forward and the right blocking finger is all they way up at the end of the cycle. Pay attention to gear box adjustments 7, 8, and 9. If your 1:1 has play, basically adjustment 9 should be changed a bit. you will want to adjust your clutch lever up a bit more so that your sweep link is a little higher than the book shows. Slowly adjust the lever higher and higher in small increments until your deck is shift all the way forwards and the blocking finger is raised all the way at the end of the pinsetters cycle....if you raise the clutch lever too much the pinsetter will continuosly cycle.
          Nick
            Advancing the timing just a liitle bit and it stopped doing it. I didn't think that the timing was so critical. Thanks for the help . I really appreciate it greatly Greg
              cool, what was you issue? is it stopping before zero, or did you need to advance it a little past zero to get the the deck shift all the way forward by the end of cycle?
              Nick
                nick
                Gear-box is stoppling before O than advancing to O as deck start deck will shaft forward 1/2" or so
                  Originally posted by wepauls View Post
                  nick
                  That would be true for a pinsetter with a good 1:1. I was just enquiring as to whether his problem stemmed from the clutch being out of adjustment (thus needing to be advanced to zero as you mentioned), or because he had a 1:1 with a bad key/ shaft keyway/ cam keyway and he needed to advance the clutch adjustment so it was stopping slightly past 0 degrees. Just wanted to bring his attention to the possible bad 1:1 so that he has it in mind for future repair depending on how bad it is if the situation does exist
                  Nick
                    We just had a problem like that. The deck would not return to the forward position (about a inch off). I adjusted the cables, no luck. I decided to change the upper and lower moving deck cables. Upper measured 3/4 of an inch longer.
                    • alexherm07
                      HELP!
                      by alexherm07
                      So my lane 18 fails to set a new rack after a 180 it still thinks that deck is empty. Idk what to do plz help. Ive done 180 adj so thats not it.
                      12-08-2009, 12:11 PM
                    • ddum
                      moving deck
                      by ddum
                      boss says 180s and not setting pins after x i go back and run pinsetter.to make long story short deck wont shift back to set ten pins then when it does deck goes down to 270...
                      09-09-2004, 08:15 PM
                    • jhova
                      deck jam at zero degrees ???
                      by jhova
                      I have a machine that functions perfectly except that when the deck comes all the way up and goes to shift forward it blacks out ....there is about a 1/4 to 1/2 inch gap between...
                      02-12-2012, 07:50 AM
                    • shawn300
                      Deck shifting
                      by shawn300
                      Ok, with the rake back waiting for pins, I can move the deck back off of the bearings at the cam plate? It is like the bearings and cam are just little to forward, deck is sitting...
                      09-13-2010, 04:39 PM
                    • Pwrstroker300
                      Moving Deck problem
                      by Pwrstroker300
                      problem? Ok guys here's one, lane 10 wobbly pin call, check adjustment on deck cables at barrell connection can't adj no more, so you install new jam cable-upper deck-and lower,...
                      04-25-2002, 04:08 AM
                    Streamlane Mask Halo Lights
                    Baddest Tool Chest In Town
                    Adios, motor boater!
                    Aluminum Repair and Welding
                    http://aluminumrepair.com/...
                    Hi, guys.
                    check this jam...
                    the ball stuck the table up
