Pin gate locking
  • Pin gate locking
    Pin gate locks and holds the 5 pin from dropping.... latch is not worn... any ideas?
    a loose cross conveyor hanging down can cause one to lock.Standing behind the machine will running watch the
    belts to see if one of them is hitting the pingate.
    Ron
      it is always at the 5 pin though
        check your turret indexing cam bolts. Might have loose bolts in the area of the cam for the 5 - pin
        Nick
          Safari:
          The five pin position is the hardest one to hold for the pingate, change the strap and the pin and readjust.
          rfm
            That's because the firmest stop when indexing is at the five pin.
            Have you checked/replaced the roll pin/bolt in the pin gate latch?
              Roscoe you beat me to it.
                An aside:
                If you don't have a solid nylon index roller installed-do so.
                Kanga, when do you sleep?
                rfm
                  the "flick-test" never fails. try that and see if it locks at all when trying it like 10 times in a row. if it locks ONE time, change strap and bolt/roll pin
                  [email protected] | jsebeny <--YouTube | Cell: 309-275-2453
                    It's a 17 hour difference. It's Tuesday afternoon and he's getting ready to oil lanes for the night league?? Am I close James?
                    jonesborobowl.com
                      He never sleeps as it is too hard to sleep upside down.
                        Thus stimulating the mind.
                        When I posted before I was just sitting down for my lunch. Now it's 6:44pm and time for dinner and some .
                          strap?
                            Strap....Open your Service Parts Catalog (Green Book) Turn to page 123. Find index #T89 The part number is 12-150057-003
                            Ok it's also called Latch Link. You can find the adjustment in the Manual. Page 3-40 #9. That has a decent picture also
                            jonesborobowl.com
                              Pingate strap. Here is a collection of different ones. The square corner means good. The sloping one is worn.
                              Streamlane Mask Halo Lights
                              Hybrid (and EcoFriendly) Bumpers (2012)
                              It's been about 10 years since we first tried this - 46 lanes and still working fine, auto air bumper cylinders on the BankShot bumpers. Here are videos of a home install with...
                              Baddest Tool Chest In Town
                              Adios, motor boater!
                              Aluminum Repair and Welding
                              http://aluminumrepair.com/...
                              Hi, guys.
