Deck hook block
  • Deck hook block
    As a complete newbie I don't get a chance to post much usefull information on this forum. So I figured something out (after MANY hours of adjusting) this weekend, that may just save other newbies a big headache. Those who have been at this a while feel free to laugh.
    It turns out that the block that the rake hook latches to has a tapered edge, and will only work properly if installed correctly.
    If it's broke it will work great.... until you stop watching it.
    Deck hook block?? Are you talking about the rake hook sweep block?/
    Marty - Pro Bowl Wezt
    56 Jap A-2's Qubica VDB's
    2 Kustodian Walkers
      mostly a Rockie mistake only happened to me one time way way back in 1969 on my first try year 2 in the business
        Oooops. Deck hook block might have a few scratching their heads. In my head I was typing rake hook, but in reality my fingures aren't nearly as eloquent.
          The mating of the "Rake Sweep Hook" and block was discussed not long ago.
          Originally posted by Steve Stafford (JBEES) View Post
          Is this what you are looking for? (Note that one link has been removed for the effect of the picture)
          Here is a pic of what the two look like if the block is installed upside down.
          Streamlane Mask Halo Lights
          Baddest Tool Chest In Town
          Adios, motor boater!
          Aluminum Repair and Welding
          http://aluminumrepair.com/...
          Hi, guys.
          check this jam...
          the ball stuck the table up
