Bad detector
  • Bad detector
    Adjusting machines after putting overlay down i had 1 that was very erratic and would not switch to second ball most of the time. It had me a little confused as it was running fine the last night before they shut down. After a little consultation with Mr Stafford, he said he thought i had a coincidence where it was bad. So changed detector, and bingo, you were right Steve, I am running fine! After looking at some of the others, i have a feeling i may as well plan on doing most of them in near future, not bad tho considering these were installed in 1958.
    Brent V
    Toes I assume?
      Originally posted by Kanga View Post
      Toes I assume?
      Yes sir!
      Brent V
        I'm about to start having similar problems on my 18+ toe detectors. I've been working on a way to reuse them and compensate for wear on the cams because the cost of detector parts is INSANE over here. These work out to be approx $50 each controller. First detector with prosthetic toes has been running almost 6 months no problem.
        The plastic is CNC machined Wearlon, which is essentially an Enviro.
          Pretty slick idea Kanga, you are now a surgeon. I have welded some in past and carefully ground them off and got away with it. Luckily right now i have enough spare detectors I'm not going to worry too much.
          Brent V
            I've got some installed the same year down here I'll let ya practice on.... won't even charge ya for it.
            If it's broke it will work great.... until you stop watching it.
              LOL! Stop out at Pheasant Lanes on the way. I work there now Brent.
              [email protected] | jsebeny <--YouTube | Cell: 309-275-2453
                I've seen that somewhere before.
                Kanga, my idea has not panned out as we discussed...yet. I have not given up yet...just wish I had more time to try these ideas.
                  I'll be intrigued to see your other solutions. Please post updates on your ideas.
                    Waiting on a bearing for the next "experiment"...
                    • JohnSebeny
                      Detector rebuild
                      by JohnSebeny
                      Last year sometime, I had an issue w/lane 1's detector. Called Steve Stafford for some assistance and we came to the conclusion that I had to change the detector (my very first...
                      10-28-2010, 09:39 AM
                    • Mechanick
                      detector
                      by Mechanick
                      I've got a couple of detectors I rebuilt a few years ago. I ripped them apart, cleaned the parts, inspected, repaired/replaced bad parts, and put back together. Is there a way...
                      07-08-2010, 07:20 AM
                    • junkmonkey
                      Inspecting the detector
                      by junkmonkey
                      When inspecting detectors what visible and none visible problems do you all find?
                      I was doing some research on this and found some interesting thoughts in the archives...
                      10-01-2008, 03:24 AM
                    • mikeb
                      Detector Discs!
                      by mikeb
                      Has anybody had problems with detector discs from Quality/Brunswick
                      From C.B.S.? I have found that the stop surfaces"projections" on the discs to be too tall,...
                      01-20-2007, 07:06 AM
                    • boogeyman
                      Detector Reassemly
                      by boogeyman
                      We've had a dysfunctional detector sitting in the back for a couple years now. I've decided to make it a project to take it apart and fix it, clean it, and sell it.
                      02-05-2009, 06:13 PM
                    Streamlane Mask Halo Lights
                    Baddest Tool Chest In Town
                    Adios, motor boater!
                    Aluminum Repair and Welding
                    http://aluminumrepair.com/...
                    Hi, guys.
                    check this jam...
                    the ball stuck the table up
