OOR LATCH MOVEMENT
  • OOR LATCH MOVEMENT
    Noticed that the latch is sometimes pulled above the pin in the crossmember. There is alot of wear on the end of the shotgun. We use elec trigger and the oor works fine except for the upward movement sometimes. The machine will sometimes not engage the rake to sweep deck. That creates a mess as new pins are set on standing pins. Worn bushings on collar? Does not appear to be the case, but maybe. Days when it works as it should. Det is in time and follower is in notch on cam through hole in side. Thanks.
    Do the oor latch adjustment. You might even have to tap the roll pin a little further thru.
      The oor works fine. I take you mean to drive roll pin further to bottom of shaft?
        loosen the bolts that bolt the shaft to the side frame and the electrical box u- bolts. then with a vice grip rotate the shaft a bit so that it will only latch when you pull on the oor lever.
        Nick
          Take a look at the end if the roll pin in the cross shaft
          where it comes in contact with the latch.
          If it looks worn enough where the latch could slip off replace the roll pin.
            all good posts,
            You want to cycle to an OOR then stop machine and Lock out tag out then pull latch and see how much of a gap you have between the lever and the roll pin.. Then adjust as necessary
            You will probably find your gap is to big... You want it to just pull over roll pin
            Mike
              Tapped roll pin further to bottom of shaft. No sweep hook engagement at all. Put back to original position (even tried higher), still no sweep hook at all. Had to lift oor blocking latch to fully upright and not working position, to get rake hook to engage block. I changed nothing but roll pin position. Now can not get any sweep hook latch connection to block unless blocking latch is totally away from end of shotgun. Link from bellcrank to sweep hook has some play by the roll pins on both ends. What happened here? Scratching my head over this on my day off.
                I would check the roll pins and link. You may want to replace them.
                If the support that roll pin goes through is a little loose you may have rotated it when you tapped on the roll pin.
                  Did you put in OOR and check what i stated above ?
                  Mike
                    Originally posted by MASTERMIKE View Post
                    all good posts,
                    Mike
                    Did what you suggested. The oor worked just as it should. The latch was just above the roll pin. I then ran a normal cycle and it would not engage the block to sweep. I raised the blocking latch up out of the way and it will engage the sweep. Still lost over this.
                      Yazu:
                      Before one does the OOR adjustment it is advisable to check the sweep hook link for worn roll pins and worn holes in the link, that has a lot to do with the final results.
                      JMO.
                      Roscoe
                      rfm
                        Yeah, what Roscoe said. Also, check to see that someone didn't lean on the link that runs from the sweep hook cam follower in the detector to the collar on the cross shaft and maybe bent it. This would change the sweep hook adj't.
                          Check the condition of the out-of-range latch... the part that sits on the roll pin... if it is pitted or wore, then you might want to replace the latch. Isn't it hardened steel? There isn't a good way to create a new surface for the roll pin to sit on.
                            If you checked what i stated then looking at what roscoe mentioned would be the next step...
                            So when rake sweep hook raises, during machine operation you are seeing the latch go above the roll pin on its own ? If so then thats all about whats left is what roscoe mentioned about the worn links and holes on the sweep hook and bellcrank
                              The latch does indeed go above the pin somtimes. I will change the link or roll pins next. I think that will solve problem. Thanks and will let you know.
                              • JohnSebeny
                                OOR
                                by JohnSebeny
                                im pretty positive that none of the 12 machines i take care of have the OOR running properly. ive read the instructions on how to do the OOR adjustment, i was just curious if...
                                06-15-2010, 08:01 PM
                              • Popeye
                                OOR roll pin
                                by Popeye
                                The roll pin in the frame that the OOR latch catches on when clearing an OOR. Is there a spec. on how much the roll pin sticks out toward the latch side?
                                06-28-2012, 10:46 AM
                              • gearhead
                                Dropping Pins
                                by gearhead
                                Jap A-2's.
                                Finally got it to drop pins for me while i ran it and it seems that the oor lever was/is getting caught on the roll pin(there's an edge on roll pin from wear?),if...
                                04-24-2003, 02:00 AM
                              • jplummer
                                oor latch
                                by jplummer
                                Is the latch 12-250044-000 needed when you use automatic oor kits. or what could happen if it was taken out of play.
                                10-11-2014, 01:32 PM
                              • PKMech
                                Swept OOR
                                by PKMech
                                Pinchasing tonight. Just had an out of range on lane 8 and it swept after I pulled the lever on the back. Not sure of the adjustment for this.
                                04-09-2010, 07:13 PM
                              Streamlane Mask Halo Lights
                              Baddest Tool Chest In Town
                              Adios, motor boater!
                              Aluminum Repair and Welding
                              http://aluminumrepair.com/...
                              Hi, guys.
                              check this jam...
                              the ball stuck the table up
