Frameworx TDM Conversion
  • Frameworx TDM Conversion
    I have Frameworx with Dual Output Ball Detect. Ball detect starts camera and IR trigger for pinsetter. Have a three wire (black,white,red) molex connection to TDM independent from the terminal strip. Tracing solder connections from TDM connection, black and white wires run thru TDM circuits, red wire not used. We also have Bowltronics IR triggering and compared wiring to it. Bowltronics red to terminal #16, black to terminal #18, no white wire to TDM. Would like to know if anybody has a way rewiring three wire connection to cube relay. Would like to know if anybody knows how to rewire before I start checking out and start blowing things up.
    The 3 wires for each detector are 2 for power and one return to perform the action. There is probably a transistor type switch within the trigger heads that sends the 3rd wire 'do' action. Brunswick did the seperate trigger heads on purpose. Zot and Bowl Tronics have a single head activating 2 circuits within their control unit. The Brunswick time delay module can't be interfaced with the bowl tronics because the circuits are different.
    In order to wire in a relay to an IR trigger head, you'd have to build the power, timing and logic circuits for the relay coil.
      So there is no way to wire directly to the cube relay discussed in previous threads?
        Not without power and controlling circuitry in between.
