Have a problem I think is related to detector, but would appreciate input before removing.
Pinsetter will stop at 180 with an empty deck;
At 90 strike, the strike cam follower drops only partially in the cam dwell, { roller does not touch cam } but not far enough to disengage the accuator link from the clutch release lever. I can manually push the end of the pin detector link approx 1/16 " to disengage accuator link, but it will not move far enough on it's own.
Am unble to find anything binding
I do see the roller drop against the cam just as deck is moving upward from 270.
Could this be a detector problem or is there something esle that cause it.
As always, any help or ideas will be appreciated.
