Converted A's, still have overtravel.
Had a broken 1-1. Changed it, put the same detector back in. Now acting weird.
The machine seems to work correctly mechanically, but it's decision making is impaired. Doesn't go to first ball. I can put it there manually, cycle, stops at 180 (no pins in machine), released then goes for floor normally, comes back up and overtravels,stops at 90 on holding hook.
I notice when I try to adjust the detector rod that the upward travel of the rod (or the motion of the disk if you prefer) does not stop where it should.
Bear with me - I'm not up on the nomenclature of the parts of the detector. Looking at the bottom of the detector, there's a latch or selector that rides the detector disk. At strike 90 it lowers. At that point it stops the upward motion of the detector rod and this is where the adjustment takes place. (1/8 gap or whatever)
On my detector this doesn't seem to be happening. I can always push the detector rod way up farther than it should go because that selector does not drop down to block it.
My question is: can this be caused by something external to the detector? I have another one I can swap in but I'd rather not find out the hard way that the problem is somewhere else.
TIA
TIA
