need some help with my lane 6
  • need some help with my lane 6
    need to know why rake sweep hook does not engage after first ball doesnt happen all the time maybe 9 times per league please help
    your oor lever may be blocking out hook lift it up for now see if it goes away if not the roller bearing on sweep hook selector may be cracked or broken.
      oor lever is up will check roller bearing thanx
        Would help if you tell us what you have, A's or A2's.
          Check your rake crank rod adjustment. Should have a gap at 135 degrees (rake crank rod straight out).
          Adjustment may be too close not allowing for a good catch. When this happens does it slip off or not catch at all?
          Also do you have auto OOR kits.
          Peanut
            does not catch at all also do not have auto oor
              do you have a collapsable sweep link...if so it may be binding and need some lube
              Nick
