bowler throws first ball and knocks down all but either the 8 or the 9 pin, but only one or the other not both. machine cycles normally but fails to go into the second ball cycle. If the bowler misses it on the second ball, the pinsetter just keeps resetting the single pin. Pads and backing plates are good.
nagging little problem - odd 8 or 9 pin only no second ball cycle
OK here is the problem:
bowler throws first ball and knocks down all but either the 8 or the 9 pin, but only one or the other not both. machine cycles normally but fails to go into the second ball cycle. If the bowler misses it on the second ball, the pinsetter just keeps resetting the single pin. Pads and backing plates are good.I DID UM THE SAME!!Tags: None
You stated that the machine will not go into second ball. Do you mean the first ball light is lit or is the second ball light lit but the deck does not stay up when the cycle begins?TSM & TSM Training Development
Originally posted by Steve Stafford (JBEES) View PostYou stated that the machine will not go into second ball. Do you mean the first ball light is lit or is the second ball light lit but the deck does not stay up when the cycle begins?I DID UM THE SAME!!
Remember the detector makes a detection at 270 respotting pins. It's strange that it does not misdetect at 90. Did you check all of your detections at 90? Make sure the deck is full. It sounds like the deck is at a lower position when it is only the 8 or 9 left. Your deck could be slightly bowed across the back or could be cracked. Is your eccentric adjusted properly? If it is bowed or cracked I believe Brunswick sells a deck straightener kit. Does your deck shift smoothly (take the cables off and shift it manually)? If it is rough that could be a sign of a bowed deck. Let us know what you find.
Jerry(Psalm 37:29) The righteous themselves will possess the earth, And they will reside forever upon it.
Just a thought, had a machine where when it detected the 1 pin only, picked it up but stayed on 1st ball. Had to knock pin over so it would set 10 new pins. 8 or 9 pin deck tippin forward maybe shorten detector rod half turn. I lenthen the rod for that 1 pin problem. Hope it makes sense.
I'm thinking the same as Popeye. It may be that the detector rod adjustment is only JUST within tolerance which is allowing only the strike controller to properly detect. Theory says this shouldn't happen, but you never know.
Adjusting the rod upwards about 1/16" may help. If you find yourself miss detecting at 90 after adjusting the rod you may want to verify your eccentric adjustment to make sure you have the correct difference between the strike height and standing pins height.
Deck pad wear won't help, and as Wepauls suggested, neither will worn stabilizers.Factory & Converted A-2 (US, Ger, Jap)
