Solenoid test
  • Solenoid test
    I'm wondering if their is a difference in the ohm reading between the 208-230 solenoids and the 115? 208-230 should be 100 ohms + or -10%
    received 2 new ones and they both read about 145 will not work on my 208 V machines. Found one that reads 95 and it works fine. Do the 115 V read higher?
    It's better to remain silent and let people think you're stupid than to speak and remove all doubt
    I know there is a difference in reading....not sure if its higher or lower, but one way to tell if its a 115v solenoid is that the 2 wires for the solenoid coil are smaller in diameter than the 230V solenoid.
    Nick
