I have been noticing a lot of my rake lift arm bumpers come off quite often. They are black, Im pretty sure that they are a genuine brunswick part. I have had these in my inventory for a long time and have not ordered any recently. Im wondering if maybe the ones I have in my inventory are a bad batch? Anyways, I am in need of ordering some new ones and am wondering if certain ones from one manufacturer are better than those from another manufacturer. Thanks.
Rake lift arm bumper
If the weight of the cushion is held by them then I can see them failing sooner.Factory & Converted A-2 (US, Ger, Jap)
Originally posted by Kanga View PostIf the weight of the cushion is held by them then I can see them failing sooner.Nick
Might be a bad batch or old stock then. I recently bought some black ones; I hope they're not bad too.Factory & Converted A-2 (US, Ger, Jap)
Might want to look at the new nylon ones from Pinsetter Parts Plus. The added bonus is that they help prevent inverted mouse traps.You don't have to be crazy to do this job...But it helps!
Originally posted by cuda96 View PostMight want to look at the new nylon ones from Pinsetter Parts Plus. The added bonus is that they help prevent inverted mouse traps.Nick
Originally posted by Kanga View PostMight be a bad batch or old stock then. I recently bought some black ones; I hope they're not bad too.Nick
Originally posted by Mechanick View PostThe one I have are probably 6+ years old, ...
Here's a handy hint. If you receive any rubber parts, put them into a ziplock plastic bag and seal it. I have found that this increases shelf life.
You might want to try the Quality part made of urethane #12-2590. Use these on the right (10) side of our machines. Lasts longer than rubber would.You don't have to be crazy to do this job...But it helps!
I use the Quality version. I have had issues with ones left on the shelf for any length of time. The urethane version seems to hold up very well...even when left on the shelf for a few years.TSM & TSM Training Development
Originally posted by Mechanick View PostI for the most part have the newer style bracket that does not have such a long slot, so Im not sure that part will work with the ones I have. How about Vantage or Zot, anybody use them? Or if nobody's having issues with the current Brunsick part, I can just order them.Brent V
Originally posted by wepauls View PostNICK
IF you order a new fiberglass rack bord no bumper needed
I think thy Wier for pin damage control on medal boards I just glue a strip of carpet can last for years if install right
I take it you are thinking I am asking about the bumper strip on the back of the rake boards...I am talking about the little round bumpers that go on the rake lift shaft v-levers for the rake lift rods.Nick
