Does anyone know where to find a A-2 japanese electrical wiring diagram
A-2 japanese
Japanese Electrical
I have it uploaded to "My Album" on my profile. Waiting for moderator approvaljonesborobowl.com
the jap pinlight cord plug is notorious for the wires coming loose from the plug. Also if you still have the 3 contact jap motor contactor sometimes the contact for the pinlight will go bad. follow the wire from the pinlight plug to the contactor and check voltage where it connects to the contactor with the pinsetter on. If bad you can move that wire to the next contact over if you dont have another one, it will work fineformerly dunsel
Originally posted by coachlon View Post
Japanese Electrical
I have it uploaded to "My Album" on my profile. Waiting for moderator approvalTSM & TSM Training Development
Originally posted by RipOwens View PostAlso if you still have the 3 contact jap motor contactor sometimes the contact for the pinlight will go bad.TSM & TSM Training Development
Originally posted by Steve Stafford (JBEES) View PostCoach...there is a mistake in that diagram. Many mechanics are not aware of the mistake. Wire 29 from the deck light receptacle should go to 14 on the motor contactor instead of 6 as it is in your diagram. Not your fault...that is the way it was printed.
Also due to copy rights, It won't be in my albumjonesborobowl.com
