I dont know
  • I dont know
    what are auto oor kits ?
    That is Brunswick equipment and is used on their pinsetters.
      Its a Kit (I BElieve for A and [email protected]'s etc) to make when you get Out Of Range, the pinsetter go back up to zero without having to pull the handle at the back..... Sheesh long time since I worked on A's I hope that definition is correct??
        ^ correct!
        Nick
          It works on both A's and A-2's. Jetbacks also.
            This is what an OOR eliminator looks like installed on a Jetback........
            With an OOR eliminator installed and properly adjusted, you'll never have an out of range during open play.
            BTW: All other OOR linkage is removed. No hook to hold on to during a cycle.
              So how do you adjust it properly so it won't have an OOR during open play but will during league or tournaments?
              I couldn't resist...LOL
                I had a feeling you'd comment on that.
                  It allows the pinsetter to cycle through after an OOR instead of stopping @ 90. It keeps the sweep hook selector back so the rake won't sweep and runs through to 2nd ball. We've installed them on all 48 of our machines, and the only call we get now is retrieving the deadwood the rake doesnt sweep.
                  On a side note, they sometimes come out of adjustment, or get stuck on the sweep hook selector (although very rarely, ~2 times in the past year) and the machine will start doing some funky stuff, like trying to set pins on top of standing pins. Its a pretty easy malfunction to find/fix though.
                  IMHO, its one of the few mods that I can say will never come off our machines
                    That can be an indicator of the rake sweep hook cam follower bearing on the verge of failure. I've had that happen with the stud type bearings.
                    • Adam_Davis
                      Auto OOR kits. Homestyle!
                      by Adam_Davis
                      Anyone with some free time, a limited budget, and wanting to install OOR kits, here's a solution. Took me about 1.5 hrs to make this using common tools. Cost? One kit for measuring...
                      12-22-2007, 03:47 AM
                    • nighthawk
                      Auto OOR kit question
                      by nighthawk
                      I installed 3 automatic oor kits and was curious as to what do you do with the now defunct oor lever assy(pg.5 gb91a).Right now they just sit back and do nadda,do some of you...
                      10-07-2003, 12:17 AM
                    • 180blackout
                      Out of Range Question
                      by 180blackout
                      For all of you "historians",
                      Has OOR technology (maybe technology is the wrong word)always been part of Brunswick machines (A - A2's)? Or was it added...
                      02-27-2003, 12:00 PM
                    • Cliff
                      auto OOR
                      by Cliff
                      we just got a kit in and a chance to look them over, seems very simple. since i hate paying for things i easily make, im wondering if anyone has made their own.
                      pics...
                      06-21-2008, 08:39 PM
                    • pnkflyd
                      OOR
                      by pnkflyd
                      how many guys have went to another center that had no OOR linkage???
                      Here's why...... My center i work at, ever since i started as a wee pinchaser has never had any...
                      04-15-2009, 04:26 PM
                    Streamlane Mask Halo Lights
                    Baddest Tool Chest In Town
                    Adios, motor boater!
                    Aluminum Repair and Welding
                    http://aluminumrepair.com/...
                    Hi, guys.
                    check this jam...
                    the ball stuck the table up
