Turret release cam
Turret release cam
Anybody have any idea as to why the turret release cam is rubbing against the turret clutch? It's causing a bind which is causing the turret turret to index slow. Any suggestions?Tags: None
Originally posted by Knowledge_is_key View PostI put the old belt back on. But the time delay still hesitates after it releases the pins and when I push on the latch it hesitates. Which tells me a bind somewhere but I can't find it.Nick
Originally posted by Knowledge_is_key View PostI use the 49.5" belt. I changed the shoulder bold
T and bushings in delay gear and still hesitating. I even loosened the gear a little bit. I am so stumped on this.
Maybe you should be using the 12-150113-600 belt (50"). What type of cam do you have on that lane? The stamped steel or the cast cam? I believe the cast cams get the 49.5" belt and the stamped cams get the 50" beltNick
you sure you have the clutch plate in the slide bolts properly?[email protected] | jsebeny <--YouTube | Cell: 309-275-2453
When you say it is hesitating are you talking about the time delay gear ? if so normal cause is lack of oil ( lubrication ) on the friction disc. bushing and spring retainer or linings and top pulley slipping. If the turret is hesitating indexing the 5 tighten the long turret belt. sounds like you solved your first problem with the short turret belt.formerly dunsel
