i have travel league right now and lane eleven will not reset on its own need help
not resetting
It could be a bad time delay module.
It could also be a problem with your rake switch in the electrical box with the lever that sticks out the backside of the box. Sometimes the lever itself on the switch assembly can break of at the tip from wear and tear. Then the clip will not be able to contact the lever and open the switch. This is one thing to look for and pobably the most common when it comes to problems with that switch. Another problem is if the clip of the rake shaft moves causing the clip not to press down on the lever and open the switch. And last and least common is that there could be an issue with the switch itself.Nick
