Cycling Problem
  • Cycling Problem
    Strange problem. Rake drops and the pinsetter does not cycle. Push reset nothing, clutch already engaged, solenoid is firing, have replaced time delay module. Problem comes and goes. Only way to get the machine to cycle is to turn it off then back on.
    If it's broke it will work great.... until you stop watching it.
    So the solenoid is firing and enagaging the GB clutch....but your pinsetter is not cycling. Doesn't seem to be an electrical problem then. Do you have an oil leak from that worm shaft? Maybe oil is contaminating your clutch facings.
    Nick
      Do you have a Pinsetter Saver installed on this machine?
      It is an electronic relay that shuts off power to the motor after a period of time so that not all of the belts are running all the time. Lights stay on so the customer doesn't see any difference and as soon as a ball is thrown the motor starts back up and cycles the pinsetter.
        That makes some sense. I have noticed at times the pinsetter will eventually cycle (most of the time when I am en-route to the closest switch). Perhaps the clutch eventually manages a grip??
          for grins adj the two 1 1/8 nuts on the worm shaft in 2 turns and then adj. the bottom 7/16 clutch adj. to get it to stop at 0. this will give more spring pressure for the clutch to engage and will change the location of the disc on the worm shaft if the splines are worn and binding
          formerly dunsel
            I would lean toward Rips idea. If the splines are bad enough, they might not allow the clutch to actually engage. Repositioning the drive disc assembly on the worm shaft just might help...but you should no doubt take the clutch apart to verify and possibly replace the worn components.
