1:1 Cover
  • 1:1 Cover
    Are the 1:1 cover's that don't use the 11-625530 "O" ring interchangeable with ones that have it?
    I believe all 1-1 covers mountings are the same with or without o ring
    I think it depends on gear-box number ?
    use a paper gasket any way [cant hart ]
      O-ring covers are way less prone to loosen the bolts, owing to more internal support.
      JMO.
      Roscoe
      rfm
        JMO.
        Roscoe
        GOOD PONT BOTHER
          Both covers will work. As mentioned by Roscoe...the O-ring version is far superior. If all you have is the one with the O-ring...you will be fine.
            Thanks guys. Just have a spare assembly (older) with a non-O-ring cover. Wanted to be sure of it's compatibility.
              Thats wee be hear
