Deck and rake will not move from in between 90 and 180
Last night I had a call, that the machine is rake down in between the 2/3/5 pin spots (not touching the deck) the gearbox clutch was very hot to touch. Deck was moving to pick up pins before 2nd ball, and stopped. all belts moving clutch is not. Today I took the GB clutch apart ( recently rebuilt) and checked parts for wear and oils or greases. Did not find any. After I take everything apart my input shaft will turn freely but after I put it back together it will not.Tags: None
first and for most remove power from machine
release rack hook try to get 4-1 link to o [ if you have a bad 4-1 ]this may not be possible
put machine on ball 2 and have helpers left deck to engage holding hook
to relieves gear-box presser
than remove elevator belt try pull gear-box belt in reverse to see if gear-box moves
let us know
Were the wormshaft splines greased?
Are there any pins on top of the deck assembly contacting the pinsetter frame (won't cause a blackout)?Factory & Converted A-2 (US, Ger, Jap)
The inside of the gearbox and worm gear looks fine. I did a complete rebuild of GB clutch and input shaft. When it was out it rotated and moved freely. When reinstalled it would not rotate. There is a pin on the moving deck but it is not contacting anything.
I don't know EXACTLLY where your machine is stopped. 1st ball? 2nd ball? what degree? But unless your deck is already all the way up, which I doubt, I would find out why you cannot lift it. There is nothing in the gear box to stop you from lifting it, even a little bit.I got it ! I got it ! Oh damn
can you get on the deck and lift the deck if you can try and get some one to help you and get it on the deck holding hook to take presure off gearbox than see if you can turn belts if not i suspect somthing is broken in the gearbox take down 4-1 and look inside thats where i would startMama said bowlers are ornery because they got all them balls and conditions are never good enough
I have got the deck and input shaft moving. What I did was took the input shaft and rotated it by hand back to 0. Put the gearbox belt and other belts on and wall la it works no binds or anything. I cycled it several times and no problems. WTF?
