The other night, thank goodness was during open play, I kept getting 180 calls on lane 31, and pins were all over the floor. So as i go down there, I noticed that the pin had failed to trigger the turret index, and the pins were stopped in the pin conveyor, but yet the pin elevator was continuing to run and having pins get jammed up in the turnpan. The pinwheel IS suppose to stop when pins are held up at snubber arent they?? What is causing the pin wheel to continue running?
Pinwheel keeps going
When BOTH of the rollers are lifted off the cross conveyor micro switch bracket at the same time the magnetic clutch for the pinwheel should 'turn off' and stop the pinwheel. If the pinwheel does not stop during this situation either the cross conveyor micro switch and/or rollers are not adjusted properly or the switch has problems, or, the magnetic clutch does not disengage when it should. As a test, unplug the magnetic clutch and run it. If the pinwheel does not run then that part is ok and you need to look at the cross conveyor micro switch and rollers.
Lock the pingate and have some pins back up in the cross conveyor, the pinwheel should stop, if not, check and adjust the micro switch rollers/brackets until it does.
Seem's like rubber boot on micro switch is dry rotted and does not let switch open, I would cut off rubber boot on switch and it should run fine. The normal mantinace for this is rubb brake fluid on rubber boot I think every quarter,I could be wrong on how often, once you have dry rott issues it is to late to save rubber boot.
look that microswitch lever stuff over good. On some A-2s, the "T" shaped lever that the cross conveyor rollers depress sometimes can get flipped on top of the roller levers that depress it down.Howard
PJ's right; this is the correct forum. It was moved here after TJ's post.Factory & Converted A-2 (US, Ger, Jap)
Even if the boot is in good shape, the boot will work against the switch, the rubber boot is not high enough on switch...it atcually is wanting to pull switch down.
To combat this, add a 1/2 sae flat washer under boot nut....this make boot higher and help switch open. Tis is a great mod to do on all machines.Peanut
