NEED SOME HELP
NEED SOME HELP
Ok I am little lost at what is going on have never had this problem before.. Anyhelp is apreciated. I have A2's What is going on is deck will not set pins. it has full deck but will not set pins. The moving deck cable came off i put that back on n still wouldnt do so. Liike its getting caught on something? cuase everytime I put back on n then trip the 180 link to set new set same thing happens the moving deck cable comes off an pins stay in chutes? What could this be anyone at all???? Thanks chrisTags: None
Something that is coming to my mind right now is possibly a bolt came loose which holds the chutes/spotting fingers onto the deck. If one of these drops, it can bind up the moving deck and cause the cable to pop off. Or maybe something got caught and is causing the moving deck to bind.
Can you move it manually and does it shift freely?
Originally posted by Chrisator View PostOk I am little lost at what is going on have never had this problem before.. Anyhelp is apreciated. I have A2's What is going on is deck will not set pins. it has full deck but will not set pins. The moving deck cable came off i put that back on n still wouldnt do so. Liike its getting caught on something? cuase everytime I put back on n then trip the 180 link to set new set same thing happens the moving deck cable comes off an pins stay in chutes? What could this be anyone at all???? Thanks chris
chris
Place your deck down to 270 setting pins with no pins remove power [ cable is off right ]
i think cable is off at deck rear pulley , the easiest way is to remove cam plate to re-wine cable
no need to menchion \/
good time to check all spotting finger bolts on all chutes
please let us know how it gos
the cable is on rear pully thats not the case. Seems when i put on deck cable on pullys noramally u pull the deck fwd n it locks in down. i am not able to do so? seems like its gettiing caught on something to not allow witch makes sense why it keeps falling off when deck goes down to set new pins? ??
Originally posted by sportlanes View PostEach chute has five bolts for each pin bucket and check each one first thing.
As far as the original question goes...if you can not move the moving deck, be VERY careful if you go to remove the Geneva plates. I would remove them at 90 degrees...deck empty...with the tension on the moving deck cables that way nothing can move unexpectedly. You would still be able to slide the moving deck back and forth to see if there are any binds...but you won't have yourself in harms way when removing the plates.
Once the plates are off...you could remove the cable from the top pulleys on the deck post and be sure the actual main shaft of the deck will rotate. This eliminates the moving deck as they are no longer connected. If at this point, everything moves freely, you can take a closer look at the Geneva plates and how they bolt up to the moving deck to be sure they themselves were not creating the bind. If this is what is happening...if you had removed them at 270 degrees with the cables slack, the main shaft would have unwound unexpectedly and you may have been injured.TSM & TSM Training Development
All good posts,
I have seen bent scissors bent upward and stop M/D from shifting...
MikeDO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
