From a first time poster looking for help
  • From a first time poster looking for help
    jgates1984
    Members
    Join DateMar 2012
    LocationParis, Tn.
    Posts0
    In Bowling Since2003
    Pinsetting EquipBrunswick "A" model
    Scoring SystemVector
    Lane TypeSemi-Synthetic
    Lane MachineKegal- Kustodian Ion
    Originally posted by jgates1984
    My name is Josh and I'm having a problem with one of our machines. Our center has the old "A" models. I can't seem to get the pinsetter of of second ball, my problem is that after it picks up the pins and respots them the deck raises up and the deck hook doesn't catch the deck and the deck lowers back to the 90 pinspot level and the rake stays up. If I recycle, it does the process again. Picks up pins, respot pins, deck and rake go up then just the deck lowers. I have changed the deck hook already and made adjustments to the detector rod and still can't figure it out. Do you have any ideas for me? Thank you in advanced.
    Joshua Gates
    Gary Center Bowl
    Paris, Tn. 38242
    He needs our help
    OUTER RESET LEVER HAS A BROKEN STUD BEARING OR A STRECHED LINK
    rfm
      Originally posted by Roscoe
      Outside reset lever has broken stud bearing, or streched link.
      cant delete other post
        you still have overtravel in use ?
        Mike
          It really just seems like a holding hook adjustment.
          70's MP/PBL/LBS,Q-Score
          Prolane Walker sport
            he never responded to my P M ?
            I hope hes ok he is near the tornado zone
            ph# not working
              Could be that the needle bearings in ears of the deck lift shaft or the bearings in the top of the deck lowering hook have gone bad and the deck will not come up high enough to let the deck holding hook latch on to it. If it continues to cycle to 90 degrees with the rake up...the detector is fine. It is doing what it should be doing.
                Steve: After rereading the first post, the rake is up with the deck down, i'm inclined to agree with your post of the inability of the gearboxs raising all the way up. Much as Keeth's post.
                rfm
                  A LITTLE FOLLOW UP
                  UP date thy got machine fixed cant remember wat was wrong
                  all good
