I have a holding hook that is catching. The machine is cycling through 1st ball. However when it is time to set new pins my holding hook is catching and will drop the pins from high and the hook stays in 2nd ball position after the cycle is complete. I did the out of range adjustment the I replaced the holding hook made the adjustment, but it is still catching.
deck holding hook
Make sure the OOR latch is not getting caught on the roll pin. Flip the latch up and run it to see if this is the problem. Another thing to look at is when your machine cycles does the rake sweep hook move? If it does shut the machine off at 0 deg. LOTO. Manually crank the gearbox forward till the rake sweep hook stops moving. Now make the deck holding hook adjustment. Let us know what you find.(Psalm 37:29) The righteous themselves will possess the earth, And they will reside forever upon it.
Are you saying the deck is held by holding hook and moving deck shifts and sets pins from that height?
If so, you might have to also check your upper detector rod adjustment...
mikeDO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
Originally posted by Popeye View PostMake sure the OOR latch is not getting caught on the roll pin. Flip the latch up and run it to see if this is the problem. Another thing to look at is when your machine cycles does the rake sweep hook move? If it does shut the machine off at 0 deg. LOTO. Manually crank the gearbox forward till the rake sweep hook stops moving. Now make the deck holding hook adjustment. Let us know what you find."Efficiency is, doing better what is already being done!"
Originally posted by riversidesmechanic View PostI have a holding hook that is catching. The machine is cycling through 1st ball. However when it is time to set new pins my holding hook is catching and will drop the pins from high and the hook stays in 2nd ball position after the cycle is complete. I did the out of range adjustment the I replaced the holding hook made the adjustment, but it is still catching.Last edited by Kanga (James); 03-22-2012, 07:35 AM.Factory & Converted A-2 (US, Ger, Jap)
Originally posted by sbrooks View PostJust to add a little more info, I bowl there on Tuesdays and It some times will drop pins from height with rake at 180 and throw pins up lane when rake sweeps forward.70's MP/PBL/LBS,Q-Score
Prolane Walker sport
