getting pin out of clutch drive disc?
anyone have any suggestions on how to get the drive pin out of the clutch drive disc(12-860626-000).i need to replace it but havent had any success getting it.thanks for any helphey just because its used doesnt mean its no good.Tags: None
I was fortunate with a pair of vice grips one time, the new ones have little splines on them so you could drill it out and just go 1 bit lower.Drill
David Bolt
Champaign, IL
USBC Silver Coach
IBPSIA BOD
IBPSIA Advanced
Technical Certified
Pro Shops
I do it just like Mechanick. Measure, mark, drill, and punch it out of there.. only has to be done once and all future repairs are a snap.Call if you need help. I may not answer but I will return your call when I get back. 757-653-7230
WD-40,visegrips,elbow grease,gratuitous swearing= works everytime. dont forget the swearing,this is VITAL for this operation,as with most other pinsetter related operations.
never thought of drilling an access hole tho, thanx for the idea guys.wish i had the same access to that infallible source of expertise on lane conditions that bowlers seem to have....
i did the vice grip and and used the punch thru the opening and it worked pretty good.i just got another one out of a machine with a bad pin.im thinking of trying drilling the 1/8 inch hole and punching it out that way.thanks everyone for the info.hey just because its used doesnt mean its no good.
