Can any of you "ole timers" answer this? A-2 with original Brunswick automatic scorer
This is a question regarding the Brunswick A-2 pinsetter with Brunswick"s first automatic scorer that was on the market until the AS-80 system was introduced. Maybe some of you "old timers" can answer this question for me. The deck (machine deck, not the pin deck) looks to have had a "plate" of somesort mounted with the scoring system that extends out left from the 2 and 4 pin area and another one mounted right of the 3 and 6 pin position. The question is what was the purpose of this "plate"? I know the machine used the pinfinder system to detect and score the pin fall on both 1st and 2nd ball. I also know the machine stoped at 270 on 2nd ball to await the next bowler to indentify there position. The only thing I could figure this set up was to detect and score a out of range pin. However I think there was something more that this "plate" did.Tags: None
Nope...that was all it did...outside of helping you bruise your shins.
This was used on the first version of the Astroline scoring system. It was called discrete scoring. The second version came out in the late 70's and was called IC scoring. It was short lived...two or three years if I remember correctly. Then the AS-80 system came out. The plates were not used on the IC scorers.TSM & TSM Training Development
Originally posted by Steve Stafford (JBEES) View PostNope...that was all it did...outside of helping you bruise your shins.
This was used on the first version of the Astroline scoring system. It was called discrete scoring. The second version came out in the late 70's and was called IC scoring. It was short lived...two or three years if I remember correctly. Then the AS-80 system came out. The plates were not used on the IC scorers.Brent V
Originally posted by Ed Fox View PostI still have the scars to prove it!
Charlie
Another thing was repairing the printer heads in the consoles. What a PITA!
I thought these out if range detecting plates on the deck were plates added to support the deck, or are those two different things? I think I might have seen what you guys are talking about once but not sure....are there pics someone could put up?
