I have a friend of mine who has come across someone with A2s for sale. He mentioned to me he wants to buy used parts from these A2's to convert to quick drop rakes. What pinsetter parts do we all need exactly? I know we need a rake shock and shotguns. Do we have to have time delay modules to do this? He currently has recycle relays inside his electrical boxes. thanks.
converting straight A's to quick drop rakes
-rake sheep shaft
-pit cushion, cushion linkage and shock (will the cushion mount brackets mount to your kickbacks?)
-triangular plates, cushion lift rods, rake rods
-shotgun and trigger linkage
-TDM, solenoid, and rake switchNick
Might be cheaper to buy the ZOT quick drop setup?? Seems like alot of work and parts to change to me, but hey if the price is right, go for it.B Mechanic Freeway Lanes of Parma
42 Old Otis A's, Steltronic Scoring, Kegel ION Sport
Go with the Zot kit for your A's. I just finished up converting our last 12 lanes to the Zot system within a week. Fortunately for us we were able to locate 12 used Zot shotguns, mounting hardware, and all relative parts associated with the system.My father told me to never get old...I should have listened!
I don't know who made our quick-drop rake kits, but they work great. Looks like it could easily be fabricated, but you have to have a dual output triggering system like the ZOT ET-2001's. Hard to explain without pics:
You have to install a separate relay in the electrical box, the same that you use for your reset solenoid:
The bracket is just a piece of metal fashioned and held in place by 2 U bolts around the stationary bar:
Then place a shock on the rake:
Call Tom Schemm at SBI in Deerfield,WI. They have converted a boatload of pinsetters. They could show you how to do it or do it for you. They can do the quick drop rake or a mini-kit conversion. depends on you situation and budget.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
Originally posted by JohnSebeny View Postmoved up to WI i see Brandon
I know another guy that has quick drop stuff i need but can no longer use it because of his scoring system. Ill have to see what he wants for it. Im interested in doing this with changing out as little as possible.The older the part, the STRONGER it is.
intresting ERT setup there Bwhite,its not a Zot,those use a cylindrical solenoid and small bracket. yours look like a pinsetter genius created a one-off system. looks like a cost effective way to get it done. nice to see an A model again....im swimmin in a sea of japanese a2'swish i had the same access to that infallible source of expertise on lane conditions that bowlers seem to have....
Originally posted by jmac33 View Postintresting ERT setup there Bwhite,its not a Zot,those use a cylindrical solenoid and small bracket. yours look like a pinsetter genius created a one-off system. looks like a cost effective way to get it done. nice to see an A model again....im swimmin in a sea of japanese a2's
When I took over the management here almost all of them were let go to the point they didn't work very well. Most didn't have solenoids on them, mechanic just took them off if they went bad or if he needed a reset solenoid. When I went through and rewired the electrical boxes I got them all working again and rarely have any problems out of them now.......
would love to see pics of the sensor set up! never heard of anyone creating thier own system before,definately worth noting.wish i had the same access to that infallible source of expertise on lane conditions that bowlers seem to have....
