If you are seeing this you are not logged in to Bowl-Tech. Remove this notice by Registering or Logging in
By your continued use of this site you agree to the following.
You are over the age of 18, have had supervised training in safety and operations for the equipment you work on. Bowl-Tech does not warrant or guarantee the accuracy of information found on this site. Bowl-Tech, its officers and site Admins, Mentors and Guides will not be responsible in the case of losses financial or otherwise as a result of use of ANY information on this site. Posts on this site are allowed by registered members and each registered member is responsible for the content of their posts.
If you can not agree to any of these terms of use above or are not at least 18 years of age you are asked NOT to visit Bowl-Tech or utilize its content. To visit the Bowl-Tech Terms of Service and Rules CLICK HERE
Please join our community. It is easy and gives you additional access to forums and other tools. CLICK HERE to join
Lane 8 deck jam tube engages every time you reset it
i have adjusted the micro switch aand replaced tthe cable and tube
it doesn't seem to work. Any suggestions The machine is Brunswick A2 Japanese pinsetter
Not sure what you mean by this. Is the pin is being pulled down and opening the microswitch and shutting off the machine? You said you changed the tube. Does it have both springs in it. Are all the deck cables on. Check the back one, it's hard to see without climbing back there. Check all your bucket bolts and spotting finger bolts. They could be jamming the deck if they came loose and are hanging down. Let us know what you find.
(Psalm 37:29) The righteous themselves will possess the earth, And they will reside forever upon it.
Had a machine couple years ago had the same problem. Turned out to be GB mounting bracket bolted around rake crank arm to main frame broke where bolted to the main frame. Worth a look.
if its blacking out when the deck is raising, watch for the large pin in the ears of the deck lift shaft working its way out of the right towards the turret frame. It could be contacting the turret frame on the way up and slightly raising it causing the blackout.....its happened to me this way.
If its happening right after zero, compare the tube assembly and springs inside them with other lanes to see if there is a difference. if it looks the same, maybe one of the springs inside is broken?
Also maybe the torsion spring on the deck is wound too tight. At 270 degrees with the deck down and empy, pull on the deck cable to feel the amount of torsion in the spring and compare it to other lanes. also feel for some kind of binding in the movement of the deck
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
