indexing past 7 pin only everytime
  • indexing past 7 pin only everytime
    when the turret gets to the 7 pin spot ...the indexing latch just bounces right over the dwell on the indexing cam....only on the #7 and everytime any thoughts..roller is good ...new ind. latch...nothing on cam...hhhmmmmm?very puzzling
    well i guess that is why u should always preview your post befor submitting lol ....ok the roller just bounces right over the high dwell of the indexing cam not allowing the latch to lock over the other roller any help greatly appreciated
      Check to make sure the cam itself is not loose. Also check to make sure the 7 pin spoon is not bent down far enough to hit the indexing trip latch.
        checked the cam is not loose and the spoon clears everything its only the #7 pin spot in the turret
          Between the 4 and 7 spots is where you start building tension on the spider release. You may need to adjust the tension on the spring for the long turret drive belt, change the short turret belt, or both.
            thanks cuda i will give it a shot and let you know
              Also make sure the 7 pin leading turret wire is not touching the trip lever
              rfm
