torpedo/ spring guide tube
  • torpedo/ spring guide tube
    trying to order one confused on book says spring guide tube and the other says rake compression spring is this the same part diff numbers ??? sorry for such a silly question
    You looking for just the spring or are you trying to build a complete assembly? I am sure someone (EBN) would have a complete used one cheaper than trying to piece one together.
    Marty - Pro Bowl West
    56 Jap A-2's Qubica VDB's
    2 Kustodian Walkers
      12-350126 I think all others #numbers are replaced with this number
        Not a silly question! If you have the newer parts catalog 3 12-902908 revised in sept. 2006 it is a piece of ...... A lot of the part numbers are wrong.
        Outside tube 12-350168
        Inside tube 12-350169
        Compression spring 12-350126
