Federal Pacific Contactor swap out of Deltrol/with thermal overload!
  • Federal Pacific Contactor swap out of Deltrol/with thermal overload!
    I'm changing out the FP contactor with a new Deltrol contactor and thermal overload/with heater. I have the Motor Start Relay with 8 wires, I believe it's the 3 pole MSR. The Deltrol is I believe 110 volts and I'm not sure on the wiring for the 110v coil and the Motor Start Relay. I have two wires from the Fed Pac. contactor from terminal 2 & 10 that goes to the MSR and I see where the wire from terminal 10 goes on the thermal overload and not sure where terminal wire 2 goes on the thermal overload/deltrol contactor. Thanks for the help, Bruce
    Bruce:
    Move the wire that is on the MSR that goes to terminal H down to G, this will give you 110VAC to the Deltrol coil.
    rfm
      Thanks Roscoe!! I hook it up like the directions and I burnt the coil of the Deltrol and new something was wired wrong!! Thanks again
        Originally posted by Roscoe View Post
        Bruce:
        Sorry Roscoe...but that would actually be incorrect. That IS what the instructions state to do but it puts the coil of the contactor around the fuse and not in-line with it. You should have one wire going from the contactor coil (6) to E of the motor start relay. There should then be a wire from F of the motor start relay to TS1-H. On the other side of the motor contactor coil (5), there should be a wire going to TS1-G. (Some drawings show the motor contactor coil as being labeled 1 and 2 instead of 5 and 6)
        The reason the original instructions are incorrect is that the other wire from the motor contactor goes to TS1-E (or B which is jumpered to E on older converted machines)...this would give the old contactor coil a voltage of 208/230 between TS1-E and TS1-H. Properly wired, the original contactor coil should have two wires going to the motor start relay. Those two wires went to a switch for each one of those wires. From there...the other side of the switches would run to TS1. One of them would go to E (or B depending on age) while the other would go to H. By moving the one from H to G...you would not have the proper protection for the coil. Although you would have the proper voltage, there is no protection...and if the fuse does blow...you could send 208/230 to the coil and possibly burn it up.
        Hope this helps...
