broken part found on the ground...
Originally posted by robert2020 View Posti just found this part laying on the ground behind the one of my lanes... and i have no clue where it goes. if any one knows where it goes or what it is[ATTACH=CONFIG]2329[/ATTACH][ATTACH=CONFIG]2328[/ATTACH]
You weren't having issues with this lane? Usually when this happens, the deck will miss the deck holding hook. Because the deck cannot lift high enough to get onto the post pin.My father told me to never get old...I should have listened!
It usually won't cause too many issues as the pin the clip goes on is almost as long as the block is anyway. When I had one do this, I thought the pin would have broken off...but it did not and the machine was running just fine. Put a new clip on along with replacing the block and all was fine.TSM & TSM Training Development
I helped a center with scotch yokes and had one missing,
There were no issues from it missing other than a little deck height
MikeDO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
