Short turret belts
  • Short turret belts
    Ok, I'll ask. Why two different lengths?
    ONE is for stamped cams
    ONE is for cast cams
      Thanks and which is which? How much of a difference is there in the height of the 2 cams?
        About half the thickness of the belt possibly more as one of the small pulleys is just two plates put together and the other small is machined offset to one side.
        70's MP/PBL/LBS,Q-Score
        Prolane Walker sport
          These are your two different cams, cast and stamped.
            I thought it had to do with what kind of pulley was on the clutch - the one piece or the split two piece style.
            Marty - Pro Bowl West
            56 Jap A-2's Qubica VDB's
            2 Kustodian Walkers
              Here is Steve's pic of a side by side comparison of the 2 types of cams.
                This is one way to tell if your belt is too short. Rotate the turret around to the 1 pin position If the top turret clutch pulley and the cam touch, your belt is too short. Stand up above your turret on the platform. (Not the catwalk, which is, by the way not a catwalk.) Observe the torsion latch shaft from above. If it is hiding under the trip lever shaft your belt is too long. (Maybe stretched too.)
                  For the cast cam it's the offset pulley.
                    Actually, that has nothing to do with it. The longer belt came out as there were issues with the clutch pulley (upper) hitting the spider release cam as the cam came around. Use the shorter belt unless the cam is striking the upper pulley.
                    When the newer stamped cam was put out, the parts book told you to order a series of parts to make the change from cast to stamped. The belt was not one of those. I have had to use the longer belt on both styles of cams so what style cam you have does not seem to be the deciding factor.
                    I know the latest parts book states that the longer belt is for the stamped cam while the shorter one is for the cast version...but the latest full parts books are the first books to state that. The annual parts book does not even state what the difference is besides length. And the length seems to have changed over the years. Started at 48 and 48 1/2 and now they are up to 49 1/2 and 50. Inflation I guess?
                    Bottom line, use the one that fits your setup.
                      Have replaced the belt with a few used ones. I get the same results. It sometimes dbl. indexes after 5 only. Other times it runs just as they drew it up. Will look closer for binds and or adj.
                        Replace the belt with a new one and see what happens. The used belts could be stretched which can lead to double indexing after the 5.
                          What lenght should I buy? Serial numbers of machines are 3400. This appears to be a hit and miss problem. Like I stated before , it sometimes works well.
                            [QUOTE=Steve Stafford (JBEES);470847]Actually, that has nothing to do with it. The longer belt came out as there were issues with the clutch pulley (upper) hitting the spider release cam as the cam came around. Use the shorter belt unless the cam is striking the upper pulley.
                            Like Steve says, use the shortest belt that will fit your machines. If the upper clutch pulley is hitting the spider cam use a longer belt. You can try looking on your existing belts for a part number. Worst case scenario, order one short one and if it works, great! If not you will have to order the longer ones.
                              I, too, agree with Steve Stafford. Use the belt that works the best. And always replace a used belt with a new one. That way there'll be no doubt if the belt is the cause of the issues.
                              One other thing. If you use the two-part tension spring on the long belt, make certain that it's not too tight. The easy way to adjust the spring is to back it off until the turret hesitates between the 5 and 9 pin positions. Then turn the spring two full turns clockwise (as you face it) and watch the turret index between the 5 and 9 positions. When the turret indexes smoothly, that's the position that is the best. Too much tension on the long belt can cause issues.
