Trouble System Switch wiring
  • Trouble System Switch wiring
    I have these on our machines and going to do some rewiring.There's four wires that goes from the switch and I don't have the schematic to show where the wire go on the TS2 term. strip in the electrical box. The wires aren't tagged in the box and all the wiring is old and falling apart. Is there a Brunswick book that shows reference numbers? I have an old brunswick service manual and it shows reference 750197 for the switch and reference 750198 for a part I don't have in the box. Thanks for any and all help, Bruce
    There is a button at the top of this page that will take you to the manuals. The schematics are in the service manual.
    By chance 750197 the cherry switch that recycles the machine? At one point there were two cherry switches in the box. I had a few machines back home that had that set up.
      My switches had 4 wires coming off of them also, but only 2 were actually hooked up. The other 2 were cut in the box. When I rewired I used the switch, hooking up 1 wire in the middle, and 1 on the top of either left or right side of the switch, then tapped 1 wire into Wire #17 and tapped the other wire into wire #35.
      http://www.bowltech.com/forums/showt...l=1#post445075
