Pit cushion mounting plates/brackets
  • Pit cushion mounting plates/brackets
    What is the best way to fix the holes on the kickback where the brackets for the pit cushions mount two. I have two lanes where the holes have "egged" out and cannot keep the bolts tight. I know ZOT makes a kit (kinda spendy!!). Just looking for some ideas... Thanks in advance.
    Dustin
    quality makes a hanger bracket that utilizes all 4 holes. There is a single and double bracket. I much prefer this to the zot plates. It is more expensive, but is a better fix.
    Your lower cost option would be to dril and tap to either a 7/16" or 1/2" size hole depending on how badly the hole is egged out, and use the larger hardware. You would also have to enlarge the hole in the aluminum hanging bracket accordinglt also.
    Nick
      Here'w a place with some answers.
      http://www.bowltech.com/forums/showt...52-Broken-bolt
        i was going to refer to that. thanks PJ
          It's not 'egged' out, it should be 'wallered' out.
            Depends on what part of the country you are in as to which is correct. Right Y'all?
              and even what country youins are in! (that's plural for all ya'll)
