1 amp fuse blowing
  • 1 amp fuse blowing
    any ideas today during leagues 1 amp fuse blew 3 times now machine is down for tonight,will be back in morning any ideas i would really appreciate it.thanks
    I would start looking at wires going to deck light [ being hit by rack arms ]
    Can you determined at wat point [ 0,90,180,270, ] fuse blows
      If it is blowing it as soon as it is turned on it is almost always the rectifier. Disconnect the high voltage wires to the rectifier and if the machine runs fine with the exception of the magnetic clutch working then replace the rectifier.
      formerly dunsel
        I have had a bad decklight ballast cause the 1 amp fuse to blow.
          right now machine has been running with pin deck lights unplugged seems to be running fine will check wires and pin deck light thanks
            Check the deck light power cord from the plug all the way to the ballast. If there aren't any obvious breaks in the insulation, it may be shorting out inside. Best bet is to just put some new wire in it.
            Usually you get shorts where it crosses the rake arms/rabbit ears. We've had a couple lanes where they rubbed on the metal beam you bolt the decklight to (forgot the technical name lol)
              Deck light mounting bracket
