I have 2 types of washers here that I am wondering if they are special Brunswick washers with part numbers, or not.
They are both thick washers. The first has a 1-5/8" OD, a 3/8" ID, and a 5/32" thickness. It looks like a pressed steel washer.
The second has a 1-5/8" OD, a 5/16" ID, and a 1/8" thickness. The inner hole has a pressed look but the outside looks machined.
These are not standard dimensions for washers so I am thinking that they are used somewhere specific in the machines, but am not quite sure where. I looked at the washer diagrams in the parts book, but it is not there....but I know that some special washers are not shown in those parts diagrams in the quality book. I am looking for part numbers because I want to get my hands on some of these washers (either one) for something I am working on where the 1-5/8" OD is perfect size and any ID less than 11/16" will be fine (because I can drill the hole open).
I have the Quality Hardware Catalog. The one you are suggesting has the same thickness, ID, and are similar in look (pressed steel) as the first washer I described, but the OD is too small at 1-3/8". The washer I have that I am looking for is exactly the same as those except the OD is 1-5/8", and unfortunatly that dimension is critical to what I would be using it for.
Both of the washers that I have in my possession are not in the hardware catalog diagrams.....thats not to say that they are not Brunswick parts, because I know of some Brunswick hardware that is not present in the diagrams. They are not standard washers and I can't find them at the local hardware store, or fastenal. So I don't know where they would be from if not Brunswick.
Material Fabricators, Inc. has been delivering the highest quality gaskets, custom washers, metal stampings, and die cut electrical Insulators in the industry at competitive prices, since 1946.
I believe wepauls is right about the larger (i.d.) of the two washers. The other sounds to me like the washer installed on the rake shock. (11-190519-000)
ME&My68
they are not 11-190519-000 or 11-190522-000 washers. The ones I have and need are 1-5/8" OD washers and these are too small
I found one that will work for what I need it for. 12-100170-015 It is the washer used on the end of the 1:1 shaftwith the 5/8" bolt. I got lucky. It is a thick washer with a 1-5/8" OD and a 11/16" ID.
Im still curious about the other washers and if and where they are used on the pinsetters
the one on the left is the 2nd washer I mentioned in the 1st quote, the one in the middle is the first washer I mentioned in the 1st quote, and the wsher on the right is the washer mentioned in the 2nd quote.
