twist lock
  • twist lock
    does anyone have a grainger number for 11-679304? It's the receptacle in the channel for the main motor?
    I would call Rick at Bowltronics for it - he was way cheaper than Granger on this for some reason that last time I bought some.
    Marty - Pro Bowl West
    56 Jap A-2's Qubica VDB's
    2 Kustodian Walkers
      Bowlmart in Oregon has them new for $24.
      http://www.bowl-mart.com/items/pinse...000-detail.htm
        The plug for the motor is 6C632 and the receptacle is 6C610..at least they should be.
        6C610 will run you about $48.60 from Grainger while Brunswick will charge you $28.71.
        6C632 will run you about $34.15 from Grainger while Brunswick will charge you $25.95
        Cheaper to get them from Brunswick...
          Usually not the case....this is an exception that I must take a mental note of!
          Nick
            Same goes for the main power plug to the pinsetter. Cheaper from Brunswick versus Grainger.
              Thanks for the info. It helps alot. I could not find it in my grainger book.
