turrett bearings oiling
  • turrett bearings oiling
    What is the best way to get this taken care of? Thanks.
    in the clutch or spider?
      Yazu:
      There are two small holes in the tin plate( that holds the oiling wick), they oil the outer ring of bearings and one oils above that tin plate and against the ring to oil the wick which will supply oil to the inner ring of bearings.
      rfm
        Also, make sure this area is very clean. Dirt will prevent a good flow of oil into these areas. Also dirt can be taken into the bearings by the oil.
          If you are into rebuilding your turret rings, you can do yourself (and anybody else you assign to oiling these bearings) a favor by being sure the oil holes in the wick retainer are oriented in the same place from lane to lane. This way you won't have to go "searching" for them. Just a thought...
            Good point Steve! Mine are not all the same and that is a pain like you said. When I rebuild mine I will put them all in the same direction! Thanks!
